Tagger
- Aug 10, 2001
- 47
I was at the understanding that the load inertia (lbft^2) is reduced or increased based on the gear ratio. Example:
10,000 lbft^2 at 756 RPM, the reflected load inertia on the low speed side of 282 (2.681 gear reduction) will give 26,810 lbft^2.
But I have seen an equation where the reduction ratio is squared. Reflected inertia = Load inertia/(reduction ratio^2).
Which is correct?
Which is correct?
