liquid applied soil stabilisation
monkeysmate
Geotechnical
Apr 26, 2015
OK.
I have a personal project where I need to stabilise a highly organic soil for use as a radio controlled car track. Because it's so organic, it's quite spongy and will cut up easily when the cars get on it.
I was after a liquid applied solution that I could effectively water on to the track surface, that would have some sort of stabilising effect, at a not too extortionate cost.
I know i'm asking a lot here, but does anyone have any suggestions?
Thank you
Not much you can do with organic soils. You can try treating with lime to a depth of about 6 inches. This will provide enough calcium that you won't affect the set of portland cement for the next phase of treatment. After the lime treatment, put in about 2 percent by weight of portland cement. That's not a lot, but you only want to stabilize, not particularly strengthen enough you could drive a vehicle on it.
This is a very inexpensive way to treat the soil, but will require some manual labor and preferably a small rotary tiller.
Thanks chaps. How would directly applying powdered hydraulic lime be expected to fair? Would I get similar results to the hydrated lime and cement process?
Thanks again for your time.
