Linear Amp
JimD1
24
I'm trying to build a 10 meter linear amp (3-30 mhz). About50 watt output using a single motorola mrf454 or equiv transistor. Any Ideas.
Any plans can be e-mailed to :
jmd445@Aol.Com
For transmitter, Class-C is used more often. You may linearize with negative FB.
Harmonics may be filtered out.
Linear -- class-A -- has lower efficiency, more power, heat
etc.
<nbucska@pcperipherals.com>
