gte682n
Chemical
- Aug 12, 2016
- 48
I would like to size a N2 purge to clear a 3" diameter line, 500 ft in length. The material that I am trying to push out of the line is a molten rosin. Viscosity is 15 cP, and will solidify at ambient temperatures. This line is steam traced, but the preferred practice it to blow this line out with steam to remove any chance of a plugged line. There is concern over the use of steam due to potential condensate and hot rosin mixing.
What methods exist to size the flow rate required for this purge? Is it just a matter of determining the time in which I would like to clear the volume, and ensure I have enough N2 supply pressure to drive the material out?
Is there a way to ensure I don't blow through the liquid, leaving the line to still contain the rosin, and eventually plug?
The steam is able to satisfactorily clear this line. Do I just ensure I have the same volumetric flow and pressure of N2?
Thank you.
Thank you.
