teokal
- May 4, 2007
- 78
Dear all,
We need LWN flanges with L=250mm, while we have available a lot of the required diameter and rating but with L=200mm. Is it allowed to lengthen the flange by welding a 2" piece of pipe and then perform NDT? The new weld - if acceptable - will be too close to the circumferential flange neck-to-shell weld; ASME VIII is not clear about the distances of adjacent welds, is there any knowledge on these two questions?
Please refer to the relative sketch, attached.
Thank you.
Only best result in absolutely necessary time
Thank you.
