Ladder Rungs
waskillywabbit
302
I need to find some specific documented information relative to materials that are acceptable to use for ladder rungs, such as ladders used on atmospherice storage tanks, pressure vessels and in general industrial applications. I tried searching OSHA's website to no avail. I have been told that rebar is unacceptable to be used as a ladder rung according to OSHA standards but have seen no such documentation and have seen rebar called out as the ladder rung material on numerous drawings and applications.
Thank you in advance for your help.
Brian
Pressure Vessels and Autoclave Systems
The above comments/opinions are solely my own and not those of McAbee Construction.
It is easier to buy ladder sections from a reliable supplier. they can be fabricated with curves, landings and railings. All of which facilitate construction and please OSHA.
Yes, but what do you do when you ARE the reliable supplier? It is a valid question, and can't be disposed of by sloughing it off on a supplier. See the discussion in the Boiler & Pressure Vessel forum.
I agree, it is silly to buy ladder rungs when we can fab them ourselves much cheaper...question remains...
Brian
Down Under the ladder rungs are generally 20mm diamater, mild steel, round bar.
The stiles are either 75mm x 10mm, mild steel, flat bar (for intermediate supports spaced at less than 3500mm) or 75mm x 20mm, mild steel, flat bar (for intermediate supports spaced at more than 3500mm)
I looked at one of our tank drawings- the vendor says for information on OSHA requirements (for ladders) see
'OSHA 1910.27'
I don't have that reg but hope this helps
