Onemorechance
New member
- May 16, 2003
- 51
Hi there,
I need to make a very light reservoir, the differential pressure should be 30 atmosphere, it should be very flexible and foldable when empty.
I was thinking of using a combination of Kevlar tissue in a Rubber matrix . Is this a good idea?
Would it be possible (instead of using Kevlar tissue) to wind the reservoir with a matrix-wetted kevlar fiber ?
At least when using rubber as a matrix I would not have matrix failure because its stiffness is very much lower than the fiber stiffness. But maybe winding Kevlar fiber in this case is not a good idea? Using Kevlar tissue is maybe a better idea? How much lower is the tensile allowable stress for a tissue versus UD fibers?
Is it even possible to use rubber as a matrix with kevlar?
Are ther maybe other solutions?
What do you think?
Onemorechance.
What do you think?
Onemorechance.
