[Journal] 'Rule already exists' Exception
kukelyk
Industrial
Mar 21, 2005
315
on the GTAC, there is a create_and_unite_two_solids vb journal, which is operating with UFModl functions,
Modl.CreateBlock1
Modl.CreateCyl1
UniteBodies
When I run it the first time, everything is OK. But the second run produces an exception at the first createblock line.
Could anyone please help me out?
kukelyk
You got here faster than I thought..
Im on NX12
Link
kukelyk
The error comes about because the journal assigns names to the system expressions that are created for the block and cylinder. On the 2nd run of the journal, those named expressions already exist and it throws an error. If you rename the expressions after the first run, the 2nd run will complete. If you want to create named expressions in your code, always check to see if an expression with that name already exists.
www.nxjournaling.com
ah, i let myself be fooled by the error message, what told 'rule'..
I could have thought..
big thanks cowski
kukelyk
