Joint efficiency - UG-27 ASME BPVC
MartinVT
9
Hi everyone!
This is my first thread here, and I’m sure it won’t be the last!
I’ve searched the forum for an answer, but I haven’t found one—so I’m relying on your expertise.
I’m designing a vessel according to ASME BPVC Section VIII, Division 1 (2023), and I’m calculating the pipe per UG-27(b).
My question concerns the joint efficiency to use. I came across the 4th answer in this thread : https://www.nationalboard.org/PrintPage.aspx?NewsPageID=144. I have a similar vessel setup: a pipe, two nozzles spaced 1500 mm apart, and two flanges.
No ligament efficiency — got it;
Cylinder joint — okay;
Nozzle joint — okay;
But why are the circumferential joints multiplied by two? Is this related to converting circumferential to longitudinal joints? If so, how is that done?
I’ve seen rules for converting ligament efficiencies (UG-52/53), but not for joint efficiencies.
Also, where exactly in UG-27 does it say that I should use longitudinal joint efficiencies only ?
Thanks in advance, and have a great weekend!
Martin
Not sure where you're reading this. Let me take a guess, and if I'm on the wrong track ask a follow-up question with the specific sentence or formula.
With a simple free-body diagram you can figure out the basic thin-plate membrane forces. The load in the hoop direction of a cylinder, which will be resisted by the longitudinal weld, is PR per unit length. The load in the axial direction of a cylinder, which will be resisted by the circumferential welds, is PR/2 per unit length. Other shapes (spherical, conical, ellipsoidal, etc) will have different formulas.
Joint efficiency is only related to the weld type and level of inspection as described in Table UW-12, not the direction of the weld / stress.
Good morning and first of all, thanks for your answer !
I'm reading this on the webpage i shared, it says
"Circumferential joints
– Table UW-12 column (c) = 0.70 x 2 = 1.4
So yes, there is probably a link with the coefficient 2 you mentionned between loads in hoop and axial directions of a cylinder, but I can't find where it's mentionned in the ASME.
I totally agree, that's what i understood, but once again, the Q&A link I shared mentions "Expressed in terms of equivalent longitudinal efficiency:"
But my main concerns are the origins of the coefficient 2.
Thank you again and have a nice day.
Martin
I've been designing pressure vessels for 30+ years and have seen the name Robert Schueler many times, so I know he's very knowledgeable, but I can't make much sense of his answer. I've never heard of "equivalent longitudinal efficiency'. Thus I only tried to give information I know, and ignored his response.
Good luck.
Good luck.
Thank you ! It has been only a year for me, so I don't know his name and often have questions.
So, according to you, the coefficient 2 shouldn't appear in these formulas ? Then the value of E to consider for the calculation of the thickness of the shell would be 0.7 ?
Thank you once again and have a nice day.
Martin
E would not be .7 for pipe. Seamless or welded (no filler metal) = 0.85
Could be 1.0 if slip on flanges are used.
NO. I said I've never heard of "equivalent longitudinal efficiency". Thus I have no opinion on how, or even why, anyone would calculate it.
My only advice would be to follow the Code rather than a 20 year old Q&A posting. If the Code is not clear to you I'd suggest asking your supervisor how to do this.
Hello David and thanks for taking the time,
Yes, I also agree with this, it says spot examined and has 0.7 coefficient, that should be 0.85.
I see your point. This is the problem, my supervisor doesn't really have a much clearer idea of the thing, and is not particularly familiar with english !
Thank you again
You generally use the longitudinal joint efficiency for the hoop stress calculation, and the circumferential joint efficiency for the longitudinal stress calculation.
Also, using 2 x 0.7 as joint efficiency would provide an allowable general membrane stress of 40% above what the code allows.
Hello Morcuse,
Thanks for your answer. Where are defined the longitudinal and circumeferential joint efficiencies ? In the BPVC ?
And why isn't it mentionned in the UG-27 ? "Common knowledge" haha ?
Not sure what you are saying here....E=.85 with no RT for your pipe.
Hey David !
How is it possible ? According to table UW-12 it can never be 0.85 if there is no RT or UT ?
Thank you
See UW-12(d).
It can be 1.0 if no RT/UT. If there are no Cat. B seams (like slip on flanges).
There are not separate efficiencies for longitudinal and circumferential. This seems to be an invention of Mr. Schueler's which does not exist in the Code. This is the primary reason I advised ignoring this posting.
There are separate formulas for longitudinal [clause UG-27(c)(1)] and circumferential [clause UG-27(c)(2)] joints in a cylinder, but they both use the Table UW-12 efficiencies.
I agree with this, but David is right when he says :
And see endnote 20 for longitudinal stress.
Endnote 20 mentions indeed the two different efficiencies. But it's the only location in ASME BPVC Sec VIII mentioning circumferential or longitudinal joint efficiency, that are not defined anywhere else.
You can find guidance in the Code on how to consider the joint efficiencies in the calculations in Section L-1.3, Nonmandatory Appendix L.
Thank you for this information Morcuse !
If I get it right it's only a "summary" of rules from UW-11 to UW-13 ?
And anyway it does not mention circumferential or longitudinal joint efficiencies, right ?
