is there any way to change Assembly Load Options while files are open?
JavadM
119
Hi Friends
here's the question
I have opened an assembly with assembly load options as bellow
is there any way to change assembly load options without closing and reopening files?
NX 1953
Best Regards
Yes.
After you change the load options, go assembly navigator , Right click top node - Select assembly
then Right click one of the selected components : Open -component fully.
Tomas
The more you know about a subject, the more you know how little you know about that subject.
Hi Tomas
thank you for your response, it works
and does it load Interpart data as well?
best wishes
