ColonelSanders83
- May 11, 2009
- 236
Hello All,
Here is the skinny.
We have a 66" diameter A516 Gr70 vessel with a 3/4" wt.
We have added three nozzles to one end (on the overhung portion of the vessel past the saddle support) and we are about to PWHT the modifications.
The costumers engineer has come out with a question from left field regarding extra support because of the elevated PWHT temperature.
We are now required to prove that we don't need additional support or exactly what support is required before we will be allowed to proceed.
I was under the impression additional support was not required, and I even showed the vessel would have a maximum stress of around 100 psi under a gravity load during an 1100F PWHT, and this is still not enough.
Please let me know your thoughts on the matter or if there are and codes or standard governing this situation.
I have attached a representation of the vessel showing the nozzles.
Any guideance would be greatly appreciated.
A question properly stated is a problem half solved.
Always remember, free advice is worth exactly what you pay for it!
Here is the skinny.
