IRD MECHANALYSIS Model 885
Relmo3
1
I came across an IRD Mechanalysis model 885 in workshop stores. It switches on but failing to load up showing the message below:
A>echo off
MS-DOS (R) is a registered trademark of Microsoft
COM1: 9600,n,8,1,-
Bad command or file name
C>_
How do I move from this screen. Your assistance will be appreciated
 https://files.engineering.com/getfile.aspx?folder=3a5f1738-9bf4-4377-95f0-0eed64f38bbc&file=20220505_232843.jpg
I don't know. But you might register and ask at machineryanalysis.org. There are a lot of vibration professionals there. And a pretty good resource for anyone monitoring rotating equipment vibration imo.
(2B)+(2B)' ?
It (DOS) appears to be looking for something on a floppy disk in drive slot A, or maybe just for a floppy disk to be IN drive A so it can record data.
Might be time to update your technology from the 1980s…
Lots of good work done and problems solved with IRD 885s.
