INTRLAINK QUESTION
Tofflemire
Marine/Ocean
Oct 3, 2002
312
Hi All,
Is there a way to set modified files in Workspace, so if you check out higher level assemblies to the same workspace these modified files will not be override by the files checking out, or have to manually remove the files that you do not want to check out at the check out stage?
Thanks in advance for any suggestions
Tofflemire
Not sure that I know how to do it directly, but you could check the assembly out to a different workspace. Once its there you can delete the models that would over-write your modified items, then you could export them to the original workspace.
Its not that ideal but it will work.
Change the setting so you only check out the selected file, not the required files.
Ben Loosli
CAD/CAM System Analyst
Ingersoll-Rand
Don't forget you can always remove the items that have a conflict during checkout.
