Green 123
Aerospace
- Feb 19, 2024
- 62
Is it possible to test/ inspect hydraulic system of retraction/extension and hydraulic system of break before installation of landing gear?
Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
I am asking about hydraulic components which are fitted to aircraftsure, mount it on a test stand simulating an aircraft.
I seek a detailed account of all inspection procedures applicable to components either integrated within the aircraft or assembled onto the main landing gear, in order to verify the serviceability and operational integrity of the main gear prior to its reinstallation on the aircraft following completion of overhaul activitiesI'd put the a/c on jacks and cycle the gear.
If you want to apply loads, like landing then you need a rig like the manufacturer's have.
What are you trying to do ? Why do you want to do this ??
is "break" a typo for "brake" ?
Are you trying to test the hydraulic components mounted on the plane ? why ??
Any sort of routine test/inspection should be defined by the plane OEM.
Any sort of non-routine testing should be defined by the OEM, having understood the problem.
do you not have the aircraft maintenance manual? surely such procedures would be in the AMM.I seek a detailed account of all inspection procedures applicable to components either integrated within the aircraft or assembled onto the main landing gear, in order to verify the serviceability and operational integrity of the main gear prior to its reinstallation on the aircraft following completion of overhaul activities
