markborges
- Nov 26, 2003
- 56
I suspect that I have something in my section that is creating this situation; however, If somebody has any insight on how intent manager works, maybe I can circumvent the problem.
More specifically, I have a skeleton and in that skeleton I have a sketched curve which I am using as a linkage driver. This sketch curve has some 50 lines/circles and this is the sketch that my intent manager has problems with. By problems, I mean that the creation of one more line, with all the automatic constraints turned off, takes a minimum of 3 minutes, irregardless of which computer I use. When I turn Intent Manager off, the speed returns to normal. The problem with working w/o intent manager is that sketcher will not properly regenerate my sketch and the additional line is lost.
In addition, I have two other similar skeletons with sketched linkage drivers that were created independently, different people, which have the same problem. If I do not have to add an additional line, these linkage drivers work very well; ie., they quickly extend and contract to some very extreme conditions with out any problems. It appears that intent manager gets confused with large (what is large?) sketches. In addition this problem seems to be progressive; ie., the more lines I put on the section, the slower it gets.
Does this make sense? Has anyone else experienced this problem?
MB
MB
