Inserting global variables into design table
SilasH
New member
Dec 19, 2006
70
If I have a variable designed to be configuration specific, in this case the pitch of a roof, but no physical dimension representing that, can I enter it in a design table? I could determine the angle and enter that for each new configuration, but I'd rather be able to simply enter the pitch, 2/12, 4/12, etc. The design table won't accept "Pitch" or Pitch or "Pitch@Equations."
Solution for the curious novices like me: you can insert values off to the right of the design table, and Solidworks won't look at them as parameters. So, I put my pitch in one of those columns, and used it in an equation in the design table to drive a dimension.
