sunthorn
- Mar 7, 2003
- 19
I have been asked to work on a inertial initiator for an artillery shell that would work at the following coditions. Its been a while since i've had to do any serious mechanical design calculations so i am unsure of how to approach calculations. Although I have no problems drafting the design idea in Acad or Pro/E.
It must initiate an all fire condition when a 950g +/- 150g acceleration of 15 milliseconds or more is applied and must no fire when a 2000g load of 5 milliseconds or less is applied.
The design i'm working on calls for a brass pistion of a known weight (60 grams or so) mounted in a SS sleave/housing. The piston would be pinned using a wire that would fail in double shear when the all fire condition exists.
In order to determine the correct sizing of a wire made from a brass alloy with known properies. Should i determine the kenetic energy of the piston generated during the firing, convert that to a force and then apply that force to the wire and work backwards to obtain a wire size that will shear at the 950g shock and not the 2000g shock.
Any suggestions would help me greatly.
Sunthorn
Sunthorn
