elpoblano
- Sep 29, 2004
- 19
An old agitator (mixer) was replaced from a side motor unit to an in-line vertical motor. The support structure (2-W10x33, 4.25' between them, 16' span) was deemed acceptable. According to my observations, the beams are rotating 8~10 degrees and this is a concern.
I reviewed the beams cpacity for static loading (floor, agitator components, etc) and they are fine. I calculated the dynamic torque and the bending moment at the shaft.
Here are my questions: Are the dynamic torque and bending moment applied to the support beams? What is the limit for the rotation of the beams? How do I determine the distance between the compression flange lateral supports?
Please help,
Please help,
