Inconel 625 Low temp service 2
Goody123
Petroleum
Nov 27, 2008
1
Can anyone confirm if Inconel 625 is suitable for Low temperature service @ -45c
Sorry this is rather fractured.
I have always found great difficulty getting negative temperature properties for metals unless they have been specifically designed for that purpose i.e. 17.4 ph 1150MM.
In the years I have been in Cryogenics we have always had to approach the manufacturer for more information.
The physical property testing at these temperatures is obviously a lot harder to under take a great deal more expensive for what must be seen as a minority of users.
B
Cryogenic material properties are available online at NIST:
And for fluid properties:
The best set of data I've found is "Cryogenic Materials Data Handbook" Fred R Schwartzberg et al I believe you can get a copy online here:
Note that none of these resources actually has Inconel 625, though they have other types of Inconel.
