inco718 1
anusca
New member
Jul 5, 2002
20
I would like to know where can I find info about inco718 or equivalent, could you help me?
"Inco 718", also known as "Inconel 718", a.k.a. "Alloy 718" is a fairly common nickel-chromium-iron alloy, sometimes called a nickel based superalloy. TVP was right that Special Metals holds the tradename, and their datasheet is at
They also have a variant that is aimed at superplastic forming applications, and that information is at
Other companies make the same stuff: Allegheny Ludlum's information sheet is at
while CarTech's can be found on their website at "Pyrotool 7" is one of their tradenames.
After reading the brochure, you can direct your questions to the technical service department of one of the producers- I've always had good experiences talking over proposed applications with those folks.
Good luck!
Lee
Lee,
Excellent follow-up. And here I was just shamelessly plugging Special Metals...[blush]
Does anyone know what the proper punishment for this offense is?
[cannon] [surprise][bomb]
[machinegun] [clown]
[flush]
Hello, thank you for the response to everybody. I would like to know if the INCO718 or the equivalents is creepable forming.
Thank you
