pvcguy
Materials
- Jan 31, 2003
- 13
Does anyone have experience designing incinerator stacks for the incineration of VCM trace gases? I apologize in advance for the length of my question.
At our plant (PVC) we use a Brule designed incinerator to burn off inert gases which vent from processes containing nitrogen and very low levels of vinyl chloride monomer (VCM). The chemical is destroyed in the Incinerator at temperature above 1600 degrees F. before being released to the atmosphere. Incineration is carried out in a fire brick refractory lined chamber . The high temperature needed to completely burn
VCM is maintained by natural gas. The Vinyl Chloride Monomer, during combustion, is connected to Hydrogen chloride (HCl), Carbon dioxide (CO2) and water vapour, which is dispersed to the
atmosphere.
The incinerator was installed in the early 1980’s. Since that time we have replaced the entire 190’ high, 3’ - 10” OD stack once and the top 3 (of 10) sections a number of times. The original design, which we have followed to fabricate replacement sections, is of carbon steel shell with a FRP (Derekane) liner and a 2 ½” refractory layer over that. I should say that we originally purchased replacement stack sections from Brule but stopped doing that after they arrived on site requiring major refractory repairs from the distanced traveled. The local contractors have done a great job of replicating what Brule fabricated for us.
Now the problem. The failure of the stack sections appears to occur when the refractory breaks down allowing the high temperatures to degrade the FRP allowing the HCL to attack the CS shell. Usually the top section sees the most damage and it has been replaced 3 or 4 times the latest being Nov 03. When the section was removed to replace the refractory on the section below was disturbed and now that section is failing. What is the latest design on a stack like this? We could go with an exotic type of metal but $ are on issue. My other question would be, is there something better than Derekane we should be using? There is no technical back up with Brule out of business.
Any comments on this would be appreciated.
atmosphere.
