Hyper-Linking a Block
tbeck11
43
Is there a way that I can click on a block in a 2D SWX drawing and have it open a PDF?
I was able to select the block - EDIT - INSERT HYPERLINK then path to the PDF file, but the only down side is that the path is displayed on the drawing. If I edit the text, I lose the path and link.
The attached JPG shows the block in pink and the text path.
SWX 2008 SP0
Thanks and Happy New Year!
Todd
I don't believe this is going to work like what you see in a Powerpoint presentation.
Not saying it can't be done with API, but I don't know of a way to make this work with what SW has to offer you right out of the package.
Scott Baugh, CSWP [pc2]
"If it's not broke, Don't fix it!"
faq731-376
Scott,
I can add a text hyperlink but just cannot get the block to link.
I smell an enhancement request.
Have a good New Year!
