malis
- Nov 29, 2005
- 31
Im working on a project that basically consists of runing number 6 size hoses thru a 180 deg. bending cable track with a bend radius of 4" and total length of 336". The hoses are clamped at both ends of the track and the working pressure is 2800 psi. My issue is that the hoses shrink to the point that they create friction on the inside of the track and wear thru as the machine cycles.
Below are the parameters I must meet.
1) Wire Reinforced
2) High abrasion resistance
3) Less than 1.2% shrinkage or alternative way to ease the shrinkage.
4)Greater than 3000 psi WP
Due to the loactaion and space requirements I cant over stuff the track or add a loop. The expansion has to be taken up by the hose or some axial expansion fitting
Any suggestions?
1) Wire Reinforced
Any suggestions?
