How to probe tension/compressin force in a section? 2
jassco
550
Is there a way to probe tension/compression force in a section from SW Simulation result, or do I have to create a bonded contact at the location of the section?
What is best way to find tension (internal force) at a section?
Best regards,
Somewhere inside the part.
Set up a sectio-clipping stress plot, then use the probe.
You can also plot P1 and P3 stresses, which will show you tension and compression respectively.
Certified SolidWorks Professional
Hi, Scheffers and KevinDeSmet:
Thanks for your feedback! Sorry I did not reply sooner. I figured out how to "probe" tension/compression force in a section. I think "probe" is not a proper term for what I need. I want to know total tension or compression (resultant force) at a section. I can achieve this with a split command to make a multiple bodies. Then I "probe" the section to get resultant forces.
Best regards,
