How to print PictureBox.Image with String Using Class
ren123
Student
Feb 3, 2021
1
I hope the title is enough to understand my problem, I just want that if the button is click, i want to print an image with some text using class,
just like this in the picture below (example print)
This is my Print.vb (Class)
Code:
Public Class Print
    Private Shared Lines As New Queue(Of String)
    Private Shared _myfont As Font
    Private Shared prn As Printing.PrintDocument
    Private Shared G As Graphics
    Public Shared Str As String
    Private Shared PhotoBox As New Rectangle(5, 5, 150, 200)
    Public Shared Photo As Image
    Shared Sub New()
        _myfont = New Font("Courier New",
                  8, FontStyle.Regular, GraphicsUnit.Point)
        prn = New Printing.PrintDocument
        AddHandler prn.PrintPage, AddressOf PrintPageHandler
    End Sub
    Public Shared Sub Print(ByVal text As String, image As Image)
        Dim linesarray() = text.Split(New String() _
            {Environment.NewLine}, StringSplitOptions.None)
        'EmpPhoto = Photo
        For Each line As String In linesarray
            Lines.Enqueue(line)
        Next
        prn.Print()
    End Sub
    Private Shared Sub PrintPageHandler(ByVal sender As Object,
        ByVal e As Printing.PrintPageEventArgs)
        Dim sf As New StringFormat()
        Dim vpos As Single = e.PageSettings.HardMarginY
        If Photo IsNot Nothing Then
            G.DrawImage(Photo, New Rectangle(PhotoBox.X + 1, PhotoBox.Y + 1, PhotoBox.Width - 1, PhotoBox.Height - 1))
        End If
        Do While Lines.Count > 0
            Dim line As String = Lines.Dequeue
            Dim sz As SizeF = e.Graphics.MeasureString(
                line, _myfont, e.PageSettings.Bounds.Size, sf)
            Dim rct As New RectangleF(
                e.PageSettings.HardMarginX, vpos,
                e.PageBounds.Width - e.PageSettings.HardMarginX * 2,
                e.PageBounds.Height - e.PageSettings.HardMarginY * 2)
            e.Graphics.DrawString(line, _myfont, Brushes.Black, rct)
            vpos += sz.Height
            If vpos > e.PageSettings.Bounds.Height -
                e.PageSettings.HardMarginY * 2 Then
                e.HasMorePages = True
                Exit Sub
            End If
        Loop
    End Sub
End Class
