Bridge_Man
- Apr 2, 2020
- 42
Hi All,
I have a two part question about section 10.10.3.4 in CSA S6-14 or S6-19 (pretty much the same)
Assuming I have a class 4 Transversely stiffened web (NO Long. Stiffeners) , and a class 1, 2, or 3 flange. and knowing that I am not designing the section, am just doing an assessment of it so the dimensions and the fact that the section is only transversely stiffened and NOT long. stiffened will not change.
1- Will I be calculating the the flange moment capacity based on its actual class (1, 2 or 3) or will I be assuming the flange is following a class 4 now (since the web is a class 4) , if am dealing with AISC this should not be the case as the flange will follow a different classification criteria (compact/non-compact).
2- assuming that I have the same transversely stiffened girder (NO longitudinal stiffeners) will I have to reduce my moment capacity by the reduction factor in the equation of section 10.10.4.4 regardless of my H/w ratio ? if not what will the difference be whether I have an h/w <150 or > than 150 , please remember that am only providing an assessment of the section not designing.
Am used to the american code not the Canadian code so some of those questions are just interpretation problems.
Thanks in advance
Thanks in advance
