How to Draw a Perpendicular Line to the end of another line 2
GAEngr
4
Dear all,
Could somebody please advise how to draw a perpendicular and have it snap to the end of another line? I can draw a perpendicular line with the "perp" (is there another way to draw a perpendicular line, icon, perhaps?) but it snaps to somewhere along the line and not at the end. Thanks.
I have arrayed the line 90 degrees about the end point
and this will you a perpendicular line.
You could set your snap angle to match the line, then draw orthogonaly from the endpoint, then reset your snap angle. A macro could easily be written and associated with a button. Here's a lisp program to do it. Save it as a text file with a .lsp extension, in AutoCAD load it and use the new command AE to run it.
(DEFUN C:AE (/ osm otm sa a) ; Set snap angle using endpoints
(setq osm (getvar "osmode")
otm (getvar "orthomode")
sa (getvar "snapangle")
(setvar "osmode" 1)
(setvar "orthomode" 1)
(setq a (getangle "\nSelect line ENDpoints to set new SNAP angle: "))
(setvar "snapang" a)
(command "line" pause pause "")
(setvar "osmode" osm)
(setvar "orthomode" otm)
(setvar "snapang" sa)
(PRINC)
The only problem with IFR's routine is that your variables aren't reset after you are done.
Flores
This resets the variables back:
Code:
	sa  (getvar "snapang")
  (setvar "osmode" 1)
  (PRINC)
)[\code]
Surprisingly, ACAD changed the variable "snapang" even though the original code was mispelled "snapangLE".
Flores
I use "_ucs"-> _object -> click the line -> "_line" -> snap the endpoint -> and draw the line (Don't forget "F8")
Lothar
Thanks, everyone for their wonderful suggestions. They were all very useful. Since I am not much of a "programmer" and not familiar with writing "routines" yet, the suggestion from Lothar using "UCS Object" was the most practical one for me. Have a great day!
I use OFFSET tru the point and the join by a line from to both ends.
Pardal
The @distance<direction is the easy way to do this type of task. The explanation to this is the @ sign starts the function then the length of line is next then< serves as the direction. example @4<30 give you a line 4&quot; long at 30 deg. your next line would be a length then <120 deg. giving you a perpendicluar line at the end of the first line, this can continue to complete your project.
Try this lisp:
; RITEANG.LSP
; Description: create a line 90 degrees anywhere along an existing line.
(prompt &quot;\nType RA2 to run.&quot;)(graphscr)(princ)
(defun C:RA2(/ P1 P2)
(setq OMODE(getvar &quot;ORTHOMODE&quot;))
(setq SANG (getvar &quot;SNAPANG&quot;))
(setvar &quot;OSMODE&quot; 512)
(setq P1 (getpoint &quot;\nPick a point on the existing line for the start of the new line.&quot;))
(setq P2 (getpoint &quot;\nPick a second point on the existing line.&quot;))
(prompt &quot;\nPick a point for the end of the new line.&quot;)
(setvar &quot;ORTHOMODE&quot; 1); ortho on
(setvar &quot;SNAPANG&quot; (+(angle P2 P1)(/ pi 2)) ); set snapang to angle of line
(command &quot;line&quot; P1 pause &quot;&quot;); draw the line
(setvar &quot;ORTHOMODE&quot; OMODE)
(setvar &quot;SNAPANG&quot; SANG)
(princ)
); End of Program
GAEngr:
In Mechanical Desktop there is a simpler method: type AMCOPYRM, then pick the line in the snap point wanted, answer yes to copy prompt and enter 90 (degrees) or the angle you want.
Explore AMCOPYRM, is a great order.
If you does not have Mec desktop, there are Lisp programs that do the same the order does.
Try Google or write a request.
Excuse my english.
Xan.
Draw the line using &quot;perp&quot; osnap, this will draw the line perpendicular to the one you choose.
Then use move &quot;end&quot; point of new line at intersection to &quot;end&quot; point of original line.
Unless I am missing something?
Maybe a little easier is to try this.
Grip the line
Hot grip the endpoint of the line
Space
Space (For rotate)
C (for copy)
90 or -90
Esc
Esc (to get out of grip)
I use this simple routine in my lisp file:
(defun c:1 ()(command &quot;ucs&quot; &quot;ob&quot;))
It sets the '1' as a command for the ucs<object like Exxit's explanation.
It is quick and I use this command constantly having to deal with roof pitches (3:12, etc.) The end of the object you select that is closest, will become the origin and the x-axis will align down the part.
Or how about this:
Start drawing the line from the other end? i.e. Make sure you have a running OSNAP set to (at least) endpoint, and voila - no programming required.
I MUST be missing something, or it would not seem this trivial...
OK, I just realized what I was missing:[blush]
The lines are not necessarily oriented with the UCS.
IN that case, some of the above answers (not involving programming) would be my choice. Another option, is to temporarily re-orient the UCS and use F8 (ortho).
Oops...
