EEAOC
Computer
- May 26, 2004
- 22
I have situation where I have a switchgear fed by four 750 kva transformers from the Utility. Since switch gear is nearly 40 years old with many loads that are unknown.
I have requested a consultant to meter the current loading on switchgear in order to ensure that the switch gear can take any additional.
I felt that in order to measure the current loading of this SW I need only one meter by which I can take reading of the main bus from which all the loads are fed. However I was told by a higher authority, that I need to use three more meters to measure the actual loading on this SW. This is some thing, I am not sure I agree as I feel that only one meter is adequate to measure the actual loading on the SW. I assume since the SW is fed by four network transformers, I was told I need 4 meters to measure the loading!
In my opinion no matter how many transformers feed the SW, finally every thing ends up in the main bus, so you need only one meter to measure the loading on this SW.
If anyone thinks otherwise please let me know why. Thank you in advance
