How do I remove acetone from waste water
atiaran
Chemical
Feb 19, 2003
15
I have nine 400 gallon totes of wastewater containing acetone (about 200 ppm) that I need to treat to remove the acetone so it can be discharged to the local POTW. Is there a simple effective way to do this?
Thanks.
You could try activated carbon filters. Stong UV and Ozone might also be used to oxidize and break the carbon structure into CO2.
contéact arbochim@online.be they will give you the solution
