How do I calculate the flammability of crude oil?
Davidorias
Industrial
Oct 22, 2002
26
I need some information in order to make an inventory of hazardous products. In this case the question is if there is made any correlation between the API grade of different tipes of crude oil and their flammabilities.
Thanks very much
Do you mean API gravity?
If yes, I don't think you can correlated API gravity to flammability. Flammability would depend on composition. You can have the same API gravity, but different composition - hence different flammability.
"Do not worry about your problems with mathematics, I assure you mine are far greater."
Albert Einstein
Have you read FAQ731-376 to make the best use of Eng-Tips Forums?
To determine the flammability of a liquid you will need to perform a closed cup flash point test to determine its flash point. Also, the boiling point temperature of the liquid and its flammable range should be determined.
