StevePAA
- Mar 21, 2008
- 28
here's a general question that would apply to any FEA program.
I've recently done some FEAs on round flat plates, fairly easy analyses, relatively low stresses, basic stuff. Lets say a 15-18" dia .5" thick plate using a .12 mesh size. Just making up numbers, I'll get a max stress of 6000 psi occuring on one node, and then on all the nodes surrounding it get 5000 psi or lower- say 15% lower on all surrounding nodes. The max stress is not in a critical area- away from any holes, edges, cuts, etc; just on the flat area of the plate. I usually discount the high value if not in a "threatening" location and use the nearby more commonly occuring values of 5000 psi to calculate the factor of safety. I don't do this if the max stress is on a corner, near a hole, etc.
Would this be viewed as ok by another FEA user who might look at one of my reports in the future, or am I setting myself up to be crucified?
