E55er
Automotive
- May 19, 2005
- 6
Hi all, I am looking to fabricate a high flow intake for my supercharged e55. i will be using 5" aluminum and rubber tubing. my qyestion is will an in-line cone type air filter work well if it were incased within the tubing itself or will it need to be mounted at the end of the tube. K&N makes some cone type filters that have the diamter to fit snug inside 5" tubing but it has a flat top metal covered top versus another manuf.'s open funnel type design. which type is better? also if the base opening is only 3" inside the pipe will this need to be opened to as close to 5" as possible if i go the incased route?
i saw a movie once where they showed old time gold strip miner's tools. one was a pressure washer (not powered obviously) which sent water down piping with reduced diameter piping along the way until it reached the end where it was blasting water to strip earth. can this principal, if it is one be applied to intake or was this because the weight of the water in the holding tank was creating pressure?
thanks for your expert knowledge.
