analogkid2digitalman
- Jun 10, 2003
- 529
Had to replace my water heater timer (again, due to chinesium relays) and went to a different make (DTWH40).
What concerns me is the new unit has terminal blocks as opposed to screw terminals. Unit is rated for 40A resistive load up to 277VAC.
My application is around 30A, was a bit hesitant to install it this weekend after seeing the terminal block connections, need to insert 10AWG stranded copper into them.
My question is- any suggestions regarding high current terminal blocks? Are they safe, should I prep the wires by splaying the individual strands flat before insertion?
-AK2DM
"It's the questions that drive us"
-AK2DM
