jlcochran1
- Oct 30, 2003
- 94
Is there anyway to hide the section view cut line in SW 2006? In standard pressure vessle detailing each nozzle is simply labeled "DETAIL NOZZLE A" etc. The drawing is not cluttered with section cut lines for each nozzle. It would not be uncommon to have over 100 section views to get all required details. Currently a work around is to create extra views off the paper to cut the scetion and drag the view to the drawing. This is time consuming. In Inventor there is simply a switch to hide the section cut line and/or section label. I have found nothing similar in SW. Without getting into a debate about standards (PV's and tanks have been detailed in the same manner for decades and our customer specifications for the required ACAD drawing format are not likely to change anytime soon) are there any easier work arounds? For example could layers be used and somehow hidden prior to plot similar to AutoCAD? Any ideas appreciated.
