fastline12
Aerospace
- Jan 27, 2011
- 306
We are working on a small water pump application. The internal pump pressures should not exceed 100psi and likely much less than that. We are trying to find the most economical route to selecting and sourcing seals. We want to use off the shelf sealed radial ball bearings between the shaft and housing but need to seal out water from coming in contact with the bearing. From my experience, some type of mechanical seal should work here but I certainly do not want to over design this and blow the budget. I doubt a simple lip seal will get this done though.
Ideas? Shaft speed not to exceed 2000rpm, pressure not to exceed 100psi. pumping potable water only.
