Bounty3153
- Jun 14, 2013
- 3
To start, I am not an engineer. However my company has put me on a project that requires knowledge above mine. I have worked on many design projects but none where the physical characteristics of the parts have been so crucial to the success or failure of the design.
I will attempt to explain the project, but there is an attachment of what I have came up with so far.
It is a clamping style fixture that needs to be secured around a 1" rod while 10,000lbf will be applied to the ears in a vertical pull. The plates are 1" thick with 1" Socket head bolts to pull the 2 plates together.
Ideally, the plates will be bolted together with enough force from the 1" bolts to basically crimp around the rod and hold it secure while cables are hooked to shackles in each hole on the end. It will be used to tension cables that will be pulled at 10000lbf.
My questions are:
1. Will the 1"-13 UNC Bolts apply enough pressure to secure the clamp to the rod and allow no slipping when the force is applied.
2. If the amount of torque needed to actually "crimp" the plates can be reached with the 1" bolts, will the socket head type bolts be the best route? Or would regular hex head bolts be more sufficient in reaching the amount of torque needed?
Thanks ahead for any response at all...
My questions are:
