HF
Chemical
- Oct 25, 2001
- 4
Hi. I am searching for a low-carbon steel that will allow me to do the following. First, the dimensions of the steel bar I will be using are 1/4" by 1/4" by 48". I will be welding this bar to other pieces of steel, painting it, and then baking it in an oven at 500 degrees F for 15 minutes. I need to bake it two times to allow paint to cure. The problem I have experienced is that the steel tends deform. There are shear strains, which are causing bending and twisting of the steel bar. Could someone please recommend a steel that would stay straight through my process? Thank you very much.
