Header files for API
manal72
8
I have some confusion about the defintions , header files, how to make them can I make them just by saving them on a C++ compiler , is an Application program interface API a way to have serial port communication really I am confused plz help
<off-topic>
bkeith
Are you aware that the second link in your sig currently points to Google?
Good Luck
johnwm
________________________________________________________
To get the best from these forums read faq731-376 before posting
UK steam enthusiasts:
First, let us know which compiler you are using. Bet to give you some idea:
- Most compilers come with standard libraries that make it very easy to configure and use serial communication.
- The APIs are declared in corresponding header files.
- If you have to use a specific API, you 'include' the corresponding header file in your .c or .cpp file and then use these functions to open, configure, read from/write to, and close the serial port. (a common example: to use console IO including keyboard inputs, I would include conio.h and while compiling, see that that the library path for compilation includes the standard library libc.lib)
Hence, more information is required to give specific suggestions.
[um.narayanan@gmail.com]
