Getting different 1st principal stress results with apdl script and workbench
BTHS
8
Hi
I have a simulation where i use a *get command to extract stress from a specific node. When i check my result with the "Maximum Principal Stress" using a stress probe option in the vertex at the node, i am getting a different result. the GET command used is:
Code:
*get, HS_10, node, HS_nodenum2, s, 1
both results are sampled at the last timestep. The results are:
[ul]
[li]0,99784 for the GET method[/li]
[li]0,99873 for the probe method[/li]
[/ul]
Why is that? Are they calculated using slightly different methods or something?
Thanks in advance
Best regards BTHS
Hi L_K
Thank you for your input! I just checked, they both output the same 3.3986e-002. Using the following command:
Code:
*get, my_04, node, HS_nodenum1, U, sum
and the "Total deformation" on the vertex at the same node.
Hi BTHS,
*GET command retrieves averaged nodal results based on selected elements. Were all elements selected before *GET?
The difference is small, could it be due to graphics algorithm?
Thanks,
Jason
