Geometry question, need outside diameter of 3 grouped objects
sciguyjim
Chemical
Jun 12, 2002
155
If I have 3 tubes, each 1" diameter grouped together at 120° angles, what would be the diameter of a larger tube which could enclose the 3 smaller tubes? There must be a formula, or 2, to calculate this. Thanks.
I don't know of a formula but why not fire up "your favorite CAD program", create your four circles and then dimension the "all encompassing" one.
My guess at the answer is that it will be D*(1+1/Cos(30)). I don't have a CAD package to verify it though.
I don't have any CAD software, just pencil, paper & a calculator.
Kiranpatel, would I solve for "D" in your equation?
This is quite simple: as the tubes have equal diameters their CLs will be on a regular triangle.
Side of the triangle: d
Height of the triangle: d*cos 30°
Distance of one vertex to center of triangle: 2/3*d*cos 30°
Diameter of the enclosing circle:
D=(2*2/3*cos 30°+1)d=2.155d. prex
motori@xcalcsREMOVE.com
Online tools for structural design
So "d" here is the diameter of the small tubes (1"). This looks good, at least better than the figures I was coming up with. Thanks a lot.
Sorry, my post was not clear enough. D is the diameter of each of the 3 tubes (1"). The term D*(1+1/Cos(30)) represents the diameter of the envelope circle. I note that the number is the same as that derived by prex.
Bob, thanks for the great link, that's exactly what I was looking for.
Being an X-tube welder I have to agree with Prex.
