gigon
- Feb 17, 2010
- 18
Hello, I want do design 2 gears with Gear Designer:
Ratio: 4,952
Helix angle: 12 deg
Module: 1,75 mm
Pinion: 21
Gear: 104
etc.
Result is very strange... The pinion has a smaller teeth than gear.... I want to be with the same profile...(Gears generated by Mitcalc are with the same profile!)
Where is the problem?
Thank you in advance!
Ratio: 4,952
Helix angle: 12 deg
Module: 1,75 mm
Pinion: 21
Gear: 104
etc.
