AreJay
Chemical
- Nov 22, 2010
- 25
Afternoon all,
I am currently reviewing a gas compression package which has relief valves coming from the system to the flare. What has been asked is the potential for hydrate formation in stagnant lines.
When considering the layout of the pipes, there are some dead legs and some slanted horizontal pipework. The pipework is open to atmosphere and can have wind blowing into it. Would hydrate formation be a possibility if fluids were dropping out? I would assume that having self draining pipework I would be able to presume that if an accumulation were to form it would simply be a fluid accumulation rather than a potential hydrate i.e. the fluids would drop out but not instantly freeze?
If I knew the temperature profile through the pipework and the pressures along with composition would I be able to calculate the hydrate formation potential in stagnant pipes?
Thanks in advance
Thanks in advance
