antonioshaga
Chemical
- Feb 17, 2016
- 5
Hi all,
I want to know gas blowby from upstream to the downstream- I have one scenario that now I'm working on. if trip on the pump can cause gas blowby from separator to the tank. I want to check is relive valve in the tank can handle gas blowby from separator or not. so what I want to ask is there any step should I follow to check gas blowby (how to check gas blowby).
thank you.
Shaga
thank you.
Shaga
