Function block prog. in Pascal
mumarzia
Automotive
May 17, 2004
1
Dear Fellows,
Can any body let me know the web address or other stuff from where I can learn programming the function blocks in pascal for S7.
I have a problem in understanding a command
temp:=DWORD_TO_REAL(db20.dbd0)
how it works.
Bye,
Umar Zia
Hello, mumarzia;
I only saw your post today, ans I hoope this answer will still be usefull.
Siemens' Pascal-like language is called SCL, and you can find the SCL programming manual at this address:
The instruiction you are looking at is a Typecast function; the value in DB20.DBD0 is a DWORD format, which you convert to a REAL (IEEE floating-point value) before loading it to the variable "temp" (which presumably has been declared as a REAL value).
Hope this helps,
Daniel Chartier
