strlengr7
- Aug 17, 2007
- 8
I have virtually an unheated metal shack. It will sit on a slab on grade with a turndown. Is is necessary for the turndown to bear below the frost depth? In my mind, only unheated bearing foundations should be below the frost depth. Even though the shack will put load on the turndown, the load is minimum. Any thoughts?
