From Sol101 to Sol601 - how to?
Wnuczko
23
I have large solid model with 7 multiple surface contact points - friction 0,1. Model was calculated with static structural analysis. LGDISP are on.
Now I would like to double check the results with nonliniar static. I can choose between 106 and advanced 601. What I need to change in my model to be able to calculate?
What I know is:
-use nonlinear contact (Frictional Constraint 0,1) property
-define time steps (10 and 0,1 increment)
In Load Step convergence graph Contact is below Energy which I assume is good to proceed. Why my simulation may stop? It is only related to settings since my model is good, since it was possible to calculate static - rgiht?
I have only 1 err: SOL601 did not finish successfully.
See picture for convergence.
Any hint will be greatly appreciated.
Rgds, W.
 http://files.engineering.com/getfile.aspx?folder=ad738f2e-105e-46f9-9801-43c8e5bcf564&file=convergence.PNG
For Sol601, you need to change your load definition to time dependent. Define a time field for the load. The first point is always 0,0. The last point is (your time step defined, your final load).
Kind regards,
Tuw
