forming 321 stainless
spilo
Aerospace
Oct 17, 2007
1
I can't get a sheet of 321 big enough to form the part I need. My supplier wants to weld 2 sheets together and than form the part. Any one have any info about using this process?
You can expect lower formability from the material in and near the weld if it is in the as-welded condition. Thermomechanical processing, even homogenization/recrystallization, would be an improvement.
Cory
After form the part it will be good to heat the forming zone at a rate of 700ºC/h than make a step of 1050ºC during a time correspondent to the thickness of your plate (if it a thin plate of 3 to 5mm a step of 5 to 8 Minutes is ok than let the plate rapidly cool in the air.
luis marques
