HughRob
- Aug 19, 2008
- 6
My question which seems embarrassing resolves around the final temperature of the downstream air flow.
If we have a duct and inside the duct is a heating coil.
Lets say the heating coil only covers 50% of the cross sectional area for arguments sake, it is obvious that only a proportion of the air will be in contact with the heater.
By the usual method we can calculate the convection transfer coefficient and therefore calculate the heat input that will occur.
To calculate the actual final mixed air stream temperature do I need to use the enthalpy change divided by the specific heat to calculate the temperature delta?
