Foam selection help
JATIII
1
I am looking for a highly flexible foam type material that must have good to excellent UV resistence. Any suggestions?
You want it supplied in what form? Blocks| sheet| self-adhesive sheet| die cut preforms| resin?
There's also a standard for compressibility; I don't remember the number.
Does 'flexible' imply that you'll be bending sheet, or compressing the stuff?
Mike Halloran
Pembroke Pines, FL, USA
What is the question exactly. Are you looking for a technical recommendation or a source of supply? Either way you need to supply a lot more info and some evidence of prior effort.
Pat
for site rules
Even without much information about the application I would say that EVA could be a good option for its versatility.
G
"Since light travels faster than sound, isn't that why some people appear bright until you hear them speak?"
