ris2
Chemical
- Aug 28, 2003
- 34
ris2 (Chemical) Mar 4, 2004
I want to calculate the flow rate from a vertical vessel to a closed tank. I know the pressure in the vertical vessel and the line size to the tank. I know also the pressure in the closed tank. What other information do I need and what calculation can I use? There is a level valve downstream of the vertical vessel which maintains the level in the vessel.
